Widgets Imported Not the Same as Documentation
Hi – the widgets that I imported from the .wie file are not the same as specified in the documentation. There are no widgets for “Home Grid 1, Home Grid 2….. etc, and the home page is not layout properly because of it. Am I doing something wrong here or is the import file incorrect?
It looks like you have the Beauty Blog theme. Which would have different instructions than the Hello Beauty Theme.
Here is the direct link for those instructions https://support.helloyoudesigns.com/beauty-blog-theme/
