Social Links Not Working in Hello Blogger
I added my social links in the Customization tab, but whenever I press on the icon, it says “URL cannot be shown”, and takes me to https://#
I’ve entered my links multiple times now, but I get the same error from the front end every time. Thanks!
When you change the link to yours, you want to make sure that you replace everything in it. Then you need to click the little arrow button that is on the side. That arrow forces the change. Otherwise it doesn’t know to stick and will revert back to what the demo is using which is just https://#
